Discuss main water upgrade .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hi Lads,
Could anybody tell if I am allowed to upgrade a mains water supply with 25mm plastic from outside the new mains stopcock ( which is on the footpath ) to the staircase at the property? its basically a straight run of 7-8m? the customer has got already the new stopcock put in at the footpath but they did not upgrade towards the property.4
For any help I would be happy.
Kind regards,
Ron
Hi Lads,
Kind regards,
Ron
Think you might have to be WRAS approved mate. But I could be wrong?
If it was a new supply you would have to give notice but so long as it goes back in between 750 & 1350mm deep and it is just a replacement for existing smaller one it will be OK.
You have done your Water Reg's haven't you Ron ?
That was my concern. So what's the procedure for that bit?
Get hold of highways department and submit a form normally takes about 2 weeks they come out and dig the hole and then refill once your finished
I was just thinking of connecting onto the existing mains water stopcock which has been already installed and I just wanted to run a bigger pipe instead of lead. I would not install a new main water at 5he street but Donne t onto it and run a new pipe to the house
Reply to main water upgrade .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
