Discuss Mains pipe in pitched roof?? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I need to get a 22mm mains to an unvented tank in my loft.
Is an old house and the first part of the roof is pitched and sloping from the inside. The easiest way to get it into the loft is straight up the wall internally and then into the sloping roof the other side of the plaster board.
This is obviously an unheated roof section would this be ok if I ran the pipe in some armaflex.
Any thoughts, thanks
Reply to Mains pipe in pitched roof?? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
