Discuss Mains stopcock stuck in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a mains stopcock that’s stuck open ( similar as in pic ) it will not turn by hand to close so my plan was this, ive squirted some WD40 into the end where the round part meets the main body I was then going to take handle off and use a spanner to try and move it but before I try this is there anything more I can do ? Like maybe heat a little ? It’s not ancient by any means was new around 9 years ago but has hardly been turned off ( no need as it was a new build ) I can isolate from outside any more suggestions gratefully accepted
pair of pliers on the handle inline to give you more leverage
Wd 40 is the universal fix it spray..and is good,, I think it
causes problems later when it evapourates after 6 months or so...just like when you eat a big mac and then want another.
Chain Saw oil or Hydraulic fluid is better in my opinion and hangs around . In your case , turn off in the road and give it plenty but only on weekdays as fitters and BQ stuff is expensive and rubbish at weekends if it all goes really wrong
centralheatking
Part of the issue of it being stuck will be calcification. Mostly this takes place and fuses parts when its turned hard off. By turning it back 1 full turn from hard off you'll minimise it.
You can safely leave the removed mech and stick in descaler (warm water) for an hour to put it back to as new or remove it and simply replace the guts.
When it goes back, remove the packing gland & grease the shaft with a light coating of silicone grease. It'll go on for ever ;)
Find out where the external isolation tap is first. Could be within your boundary, but most likely on pavement or road. Sometimes isolates more than one property, so check with neighbours. Be prepared for outside tap chamber to be full of crud if not touched for some time. If it is inaccessible, then contact water co as its their responsibility to have it working. Once you know you can turn off outside, then start messing with stopcock. They can easily be serviced with a few spanners. You can free a stuck tap by slotting large ring spanner over one side of handle and applying leverage. Some adjustable spanners have a nice hole in handle that can fit well. Move in small increments both ways to loosen off. Always turn back 1/4 - 1/2 turn after fully opening.
Reply to Mains stopcock stuck in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I've joined the forum today as I've found myself going round in circles with what I think might be a pretty simple problem, hoping...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor...
I have a seemingly impossible problem. I am not a plumber but I can at least understand some of it. We have just had the Water Board inspector...
