Discuss Making compression fittings in tight spots in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bright spark
Does any1 have any neat tricks for working on compression fittings in tight areas.
Does any1 use any ratchet spanners etc or just take lumps outa your fingers.
i know push on fittings are a god send but can't b used on gas.
thanks
A few tricks, where possible, can make life easier.
One is to first compress anything you can out of place and then redo the joint(s) by hand in position so that just needs a nip up with a spanner.
Paste fittings so that it has less friction so less force and no squeal.
Have a wide jaw short arm Bahco adjustable for awkward spots. (I use 8")
Use a compression elbow with a short piece of copper in one end to use to tighten to other side of fitting, giving you plenty of leverage and only needs one spanner. Do make sure depth of elbow is same as connector or whatever actual fitting is to finally tighten to that nut & olive though!
I bought a cheap stubby wide jaw, then made it a mega stubby with the help of a 4" grinder...
monument tap spanner, 6'' widejaw bacho, open end ring spanner.....
then, if in doubt..rip it out and re-route.
Reply to Making compression fittings in tight spots in the Plumbing Jobs | The Job-board area at PlumbersForums.net
