Discuss Manifold hot cold plumbing in the USA area at PlumbersForums.net
Hello again. I'm moving forward with my new-build project on, I need to plumb my 3 wet rooms up stairs, a downstairs loo and kitchen/utility.
Due to lack of availability of a decent local plumber I'm doing the work myself.
I wanted to use manifolds for hot and cold supplies. 22mm to feed the manifolds and 15mm pipe from the manifolds
My question is, does each individual appliance eg bath, shower (thermostatic mixer-balanced hot cold feed), sink and toilet, need a completely separate hot and cold feed from the manifold or can I 'T' off one feed to the cold feed for sink and toilet and bath in the bathroom area?
Same question for hot on the separate shower and bath, can I 'T' that joint too?
The pressure is pretty decent in our village, our old house has 5 bar static, the new build has new water main.
Being able to T would reduce manifold sizes. I was just checking if this is the normal way to plumb up bathrooms
If my thoughts are incorrect then what is the normal way from a manifold to plumb bathrooms?
If it’s new build I would be more concerned about putting in upstairs wet rooms before any settlement/ timber shrinkage has occurred. Obviously this depends a bit on construction methods - but this can be a disaster waiting to happen, they will fail....
Are you fitting an unvented cylinder with balanced cold?
What part of the country? someone here might be local
Yes its un-vented cylinder with balanced hot cold feed. Its the UK
With a balanced hot/cold supply I would like to know if connecting the bath and sink hots together under the bath would be ok, same for cold?
. This would reduce manifold size in the airing cupboard. I would also put inline isolators on feeds at sink and bath.
@ Bee gee
The building shell, roof on with windows and doors installed has been sat nearly a year. Its very dry now. The concrete floor is under 10 dampness reading (calibrated damp meter)
Yes there fine would do them in 22mm with secondary’s depending on length
Reply to Manifold hot cold plumbing in the USA area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
