Discuss Marley push fit 15 mm any good? in the USA area at PlumbersForums.net
Hi there
Has anyone used Marley equator pushfits to connect 15 mm copper pipe for central heating?
Thank you
Reply to Marley push fit 15 mm any good? in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
