Discuss max and min burner pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
when testing max and min pressures on gas valve,max is ok but when removing wire from valve to reduce to min and it justs stops at max,am i to assume the potinometer or what ever they are called,is not increasing and decreasing current to gas valve,i got 10 k ohms when slightly warm so ntc not,i got info on altering pot,so i'll give that a go faulty,going back tomorrow any help appreciated.
Reply to max and min burner pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
I have a customers trianco burner that starts from cold ok for a few minutes (say 3minutes) then locks out then will not stay on. Boiler had not...
I got a problem with my boiler,it's got some vibration when it starts to work,it doesn't fire up unless I duck tap and blank half of the air...
