Discuss MDPE to copper lever valve in the DIY Plumbing Forum area at PlumbersForums.net
I would like to fit a full bore quarter turn valve that takes 25mm MDPE on the inlet and 22mm copper on the other side. I can't seem to find one, but surely they exist - has anyone come across one?
I need to replace a seized stopcock on a 25mm blue MDPE supply pipe to 22mm copper internal pipework and my preference would be for a full bore lever valve that's a direct fit to both pipes (less prone to seizing I hope).
If such a thing doesn't exist, then I'll use a converter on one of the pipes but I want to consult with those better informed than myself first.
Reply to MDPE to copper lever valve in the DIY Plumbing Forum area at PlumbersForums.net
Hi all, we're doing some renovation work to our property and we wanted to install a sauna house (includes shower) in the garden, irrigation system...
2K
We just had a waterhole bored and were lucky enough to find a flowing artesian, which delivers just over 500 gallons an hour without needing a...
Hi - recognise this a bit of an odd one. We have an old failed mixer valve which we need to replace. This valve actually predates a temperature...
Hello all, Currently suffering from poor internal flow rates near the internal 20mm stopcock of 10L/min. Want to upgrade system to either...
2K
