Discuss MDPE to copper lever valve in the DIY Plumbing Forum area at PlumbersForums.net
I would like to fit a full bore quarter turn valve that takes 25mm MDPE on the inlet and 22mm copper on the other side. I can't seem to find one, but surely they exist - has anyone come across one?
I need to replace a seized stopcock on a 25mm blue MDPE supply pipe to 22mm copper internal pipework and my preference would be for a full bore lever valve that's a direct fit to both pipes (less prone to seizing I hope).
If such a thing doesn't exist, then I'll use a converter on one of the pipes but I want to consult with those better informed than myself first.
Reply to MDPE to copper lever valve in the DIY Plumbing Forum area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
