Discuss Megaflow & Heating fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Boiler then if an early logic system bet the hex has gone?But both of these faults would mean water discharging through the PRV pipe from the boiler outside right? She did say she hasnt seen anything discharging from this pipe. (she could be wrong i guess) i mean who stands outside all day looking.......
I have a Mega Flow system and the hot water is not very hot. It was very hot but now is tepid. Any ideas what the problem might be ?
Cracked heat exchanger in the boiler. If no obvious drips under boiler, pressurise the CH, turn boiler off, and if condense dripping / running through then you have a crack in heat ex.
added: above assumes that its a condensing boiler.
Reply to Megaflow & Heating fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
