Discuss meter to boiler pipe size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, In the near future would like to change standard boiler for either same or combi , meter is at one corner of house and boiler diagonally opposite, pipe starts at 22mm from meter but ends up 15mm at boiler, concrete floors so assuming pipe goes up to and into 1st floor cavity and accross approx 45'.
I am guessing boards will need to be lifted to check where 22 stops. Is there a way of measuring the gas flow to end of 15mm pipe to see if it is enough to fire a combi? Incidently we have a gas fire in living room but very rarely use it at all, 1 main and 1 ensuite 3 bed detached 12 rads total 3 double cheers guys.
There is a way of determining the correct gas pipe size required for your appliance, It is quite a complex equation taking into account a whole load of variables and is the job or responsibility of the Gas Safe Engineer you employ to determine the correct pipe sizing. They may even find that 22mm is not going to deliver the amount of gas required for the combi to operate safely and opt for bigger pipework.
To sum it up, let your GSR decide what is correct.
(gets out *** packet) for a typical combi you're looking at about 30kW if you want a half decent hot water flow, compared to whatever (12kW?) for your present boiler. 28mm pipe at least to keep the pressure drop within spec.
It wasn’t based on the existing gaspipe as there are ways around that in terms of where you run it. I was really imploring him not to get a combi boiler if he is going to run two bathrooms as its not up to it
My advice:
Get a trusted plumber in, discuss what you require in terms of heating and hot water and see what he / she recommends.
My personal view ( for two bathrooms ) is to go unvented and system boiler. Others may prefer the Combi route - it often works for large houses with only a couple living there.
I suspect that which ever route you go, the gas supply to the boiler will need to be resized and routed to current regulations anyway.
Reply to meter to boiler pipe size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
