Discuss MHV system Ecocent maxi boiler needs fixing and servicing, and air source heat pump needs servicing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PCJ
Hi, our Ecocent Maxi 3001 boiler needs fixing. It comes on for a few seconds then blows the electrics. The immersion does work though when the boiler is on standby so we can get hot water. The manufacturer has indicated they assume the problem is the capacitor or the compressor. We’d like someone to come to fix the boiler and also service the mechanical heat and ventilation system, and also the air source heat pump. We are in Llantrisant, South Wales. Thanks
Reply to MHV system Ecocent maxi boiler needs fixing and servicing, and air source heat pump needs servicing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
