Discuss microbore valve connection in the DIY Plumbing Forum area at PlumbersForums.net
Hi all, just removed a radiator while decorating. One side was easy, the other just spun round and is now leaking. Have drained down system but not sure how to fix leak (not seen this connector before) ps was really tight - split the olive? The whole connector is spinning round.
Thanks in advance.
So it measures 8mm od just above the paint ?
Was the valve a trv ?
Yes snap reducer
You need to remove all the water from the pipe before soldering
You will need an 8mm coupling, short bit of 8mm pipe and either a 3 part reducer 8-15mm or a soldered 8-15mm reducer and a 15mm olive
Thanks Shaun. Mrs said I should have left it and just papered behind but like to do things properly and when I took the rad brackets of only 2 screws were doing anything so going to sort that.
Appreciate your quick replies.
Hi all, just an update (sorry took so long).
Cut off the adaptor and there was no sign of an olive. Bought a new adaptor (olive included), cleaned pipe, tightened up and all ok.
Thanks again for everyones help.
Reply to microbore valve connection in the DIY Plumbing Forum area at PlumbersForums.net
