Discuss Mira shower mixer adjustment. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT.
THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE.
THANKS
What’s the hot water system eg cylinder with tanks in the loft ?
Closed pressurised system fed from Air Source Heat Pump. Cylinder in airing cupboard. Both hot and cold water have the same pressure.
Would say the cartridge is on the way out then aslong as your other hot water outlets are ok and the filter in the shower is clean
There is a temperature adjustment screw in the centre of the cartridge, I think it’s a little Allen key.
I would try this first before replacing the cartridge as often it is all that’s required.
Look up the instructions online for your particular model.
Thanks Ben. You are quite right. Found the instructions on line so good to go!
Topic closed, thank you all.
Reply to Mira shower mixer adjustment. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
Hello! Im Martyn Im new here and have joined for some advice on a couple of things. Ive got an issue with a Mira mixer shower that has...
Hi all, can someone get to the bottom of this before I call a plumber, en suite shower started leaking from the mixer bar so took the shower off...
Hello all, So been having somewhat of a time with my Aqualisa Quartz 9.5 electric shower. A few.month ago I put up with a few problems it was...
Hi im just starting new shower in our new extension. Its a concealed thermostatic mixer from victorian plumb, no instructions. Im putting the...
