Discuss Missing bits for my wall hung toilet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
My plumber says I’m missing the bits that go into the back of the toilet (two small holes either side) he’s only fitted side fixing ones before he’s says. Anyone know what they are called. Unfortunately I bought from Victoria plum and they are no use
I’m guessing wall hung toilet and frame ?
Yes it’s this toilet. I have an existing saneux frame already built in.
they come with the frame so I guess there in your old pan
AFAIK, 'mounting studs' are the bits that are fixed to the wall frame. After they've been adjusted to the correct length, these are covered by 'stud caps'. The bits that go in the pan casting and that you tighten to hold the pan onto the stud caps are the 'mounting receivers'.
I'm not sure how standardised these terms are.
Reply to Missing bits for my wall hung toilet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
