Discuss Missing/broken water shut off valve tap/switch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wordy30
Hi everyone,
Recently we have been having problems with our washing machine and need to buy a new one. We need to turn off the water supply going to the washing machine but it seems like someone has broken the shut off valve tap/switch (see pictures). Would it be possible to just buy a new tap/switch or does that entire section need replacing?
Cheers
Trace the pipe back and find the incoming stop valve (usually under the sink), isolate the water then replace the isolating valve once you are sure the stop valve works.
And welcome to the forum.
best to replace the washing machine tap
http://www.NoLinkingToThis/p/washing-machine-valve-without-check-valve-15mm-x/51231
also if you dont use the hot one might be worth capping that off with a 15mm cap end (remove the washing machine valve)
Washing machine tap also known as isolating valve in case of any misunderstanding.
If all goes well the existing nut and olive on the 15mm copper can be reused. One pair of grips to hold the valve in place and a spanner to undo & retighten the nut from the valve.
However this means isolating the hot water incoming, different to isolating the cold supply.
if not on a combi yes
Reply to Missing/broken water shut off valve tap/switch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
A few months ago I wanted to connect a 1000l water butt (fabricated from galv steel) to our washing machine. After trawling many forums and...
Looking for advice please, our plumber has left us in it and I think I may know why. So they where supposed to be fitting a cloakroom sink...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
We have recently had water hammer issues. Plumbers have installed an arrestor near our kitchen sink and a device in the toilet cistern to slow...
