Discuss Mixer shower pipe sizes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a mains shower mixer. It used to be a Mira but I replaced the mixer tap some years ago. Just recently I thought I'd replace the shower head too because it's getting long in the tooth and the swivel ball joint is rather corroded and has lost some of its chrome plate. So I purchased a new head, but the fittings are different - it has a female 1/2" BSP thread on the back of the swivel joint, to screw onto a threaded pipe (the existing one has a flange on the end of the pipe and a female nut into which the swivel joint screws). I bought a new pipe as well, but it turns out that is a bigger diameter than the current piping, which is 15mm chrome pipe. The new shower pipe looks to be around 18mm dia, so while it fits the shower head, it won't fit the wall bracket. Everything from the mixer tap up to the shower head is currently 15mm. Is there some way I can convert between the two, or do I have to either buy a new mixer tap or just abandon the idea and stick with the old fittings?
Many thanks
Nick
Picture pls
Here you go. General view, valve, wall bracket, old head, new head.
are they both the same thread eg the the new one screw onto the old head?
I think more like male iron to male iron, ie a 1/2” nipple barrel - brass would do as you could cut it down so none was showing . Will cost less than a quid.
Shower engineer, yes, that looks ideal. Thanks. Ben-gee - not sure I follow your suggestion all that clearly. I get that I could screw one end into my existing nut on the end of the shower pipe and the other into the shower head, but surely there'd still be the brass flange showing in between (although maybe there are chrome plated ones available too?). I also like the idea of replacing the nut at the wall end which has lost some of its plating.
Thanks very much both
Reply to Mixer shower pipe sizes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON...
