Discuss Mixer tap flexible hose being cut in the USA area at PlumbersForums.net
Hi, I have a mixer tap with flexible hose which have been cut on the bottom.
Can they be reconnected? what type of connector I need?
Might unscrew from tap, then take to plumbers merchant. Replace as a pair and dont, twist, over bend or stress the flexis.
Thank you. Do you mean that pipes can be disconnected from the bottom of the tap ?
Yes, many if not most of them do unscrew and are usually or rather should be in there only hand tight. To get the old ones out just grab them one at a time and see if you can twist them out anti-clockwise. If you can get them out, take them to a plumber's merchant and match up the connection size to a new set and fit to the tap.
Reply to Mixer tap flexible hose being cut in the USA area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
