Discuss Mixer tap leaking from base of spout in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I am after a bit of advice on a leaking mixer tap in the kitchen.
Water is leaking from the area highlighted and varies with the amount of water pressure when using the taps, that might seem obvious, but I am not DIY minded :).
I have removed the mixer and replaced both O rings on the base but it's still leaking, although maybe slightly less. Any suggestions would be welcome. I have I just got the wrong size washers? I did match them when they were replaced.
I have done some research, and everything points to it just being those o rings.
Reply to Mixer tap leaking from base of spout in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
PSxxxxxx
