Discuss Mixer tap on a gravity fed hot water system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
Just moved into a house and out of several things the wife complained about was that there were seperate taps for HOT and COLD in the bathroom sink. She wanted a MIXER instead and she gets what she wants.
The basin HOT water tap is gravity fed but the mixer shower valve is pump fed (negative head). The expansion tank (at the top), header tank (in the middle) and copper tank (at the bottom) are all in the first floor airing cupboard.
The issue I've now is that the HOT WATER pressure is much less compared to stand alone tap. The COLD WATER is as good as before but when used as a MIXER tap, the cold is actually pushing HOT WATER back and filling up the HEADER TANK (overflow fitted).
When installing the mixer basin valve, I used the flexi hoses with isolation valves built in. Can they reduce the flow rate?
Is there a way to fix this or should I go back to stand alone taps. I could put pressure reducing on COLD TAP but how to get the HOT WATER back to its original flow rate?
OR should I feed the HOT WATER from the pump.
The hot water flow rate in the kitchen sink (mixer tap) is also not very good. What I've also noticed is that the OLD ball valve in the header tank is slower to fill the header tank compared to the New ball valve in my cistern. Not sure if it matters though in this situation.
Thanks for yout help in advance..
There is a similar thread not that further down forgot the name.
You could reduce the flow using the service valve just close it half way.
I can't remember the other solutions...
Thanks mrlennie
You could control the flow, not the pressure through the service valve and it will affect all other parts of the house (including garden hose) which I don't intend to.
I can possibly control the flow through the isolating valve on the flexi tap hose, but do I need to do that?
How do I get the hot water flow rate back?
Yes I meant the valve on the flexi. Try it see what happens. you need a screwdriver to do it.
How do you get the hot water pressure back? It may be low because your cold is forcing it back? Is it low all over the house? I'll just re read your post...
OK, I will change the pressure setting on the flexi valve, but I doubt that will change anything.
Hot water is weak on it own, without the mixer (COLD inlet) affecting it, which is the main problem!!
If it is low all over the house then it may just be where the tank is situated. You mentioned you wanted it back was it fine at one time?
Yes it was fine when I had seperate HOT and COLD single taps instead of mixer tap on the sink.
However, the HOT WATER pressure is low downstairs as well in the kitchen (mixer tap again) but not as much as upstairs.
The copper tank is placed at the bottom of the first floor airing cupboard, its actually wedged between first floor and ground floor.
Could HOT WATER low pressure symptom be linked to the header tank by any chance?
The pressure at the hot tap is governed by the height of the cold cistern.
If the cistern is 2m above the tap the pressure at the tap will be 0.2bar (near enough).
The pressure on a cold mains pipe ranges from around 1 bar to as high as 10 bar. (If it was running from a cistern, it would be 10m to 100m above the tap).
Your old taps were made to suit low pressure with big waterways inside. Most new mixers are only suitable for high pressure (although you can get low pressure ones) and should be supplied from balanced supplies with check valves fitted to the tails.
If, as it sounds, your cold is mains fed the tap will never work properly no matter what you do. Fitting a pressure reducer to the cold will only make the cold as bad as the hot. You need to buy a different tap or learn to live with it. (or change your system to an unvented or a combi.)
Thanks tamz
The water level at the header tank when its full (ball valve closed), is about a meter higher from the basin tap, so you are probably right that here is not enough pressure for the HOT WATER TAP.
Buying a new tap won't be easy as this tap was bought specially when I was in India. I've a lovely but 2 hole basin in bathroom and I could not find any mixer taps with flexible legs for a 2 hole basin here. So I bought one when I found one in India. Due to its flexible legs, it also makes the tap outlet much higher than the previous single taps, which does not help!!
I've another option I think, I've pumped (Single negative head for HOT water only) supply for Jacuzzi, should I link the pump outlet to basin HOT WATER tap as well?
Hi again
I've attached pics of my new mixer tap. I find it weird looking but missus likes it. I've also attached a pic of my airing cupboard setup.
So I am going to give it a hot water feed from the shower pump unless someone on here tells me otherwise (please let me know in time).
SOOO many thanks once again for your help.
Its because u don't find them in UK, even though mostly everything on sale in UK comes from China.
Hope you also managed to see the useful side of it.
If you could also see my previous posts, you might get there!
Its a MIXER TAP ON A 2 HOLE BASIN. How many have you seen and installed?
However you go about it, your pressures need to be balanced.
You might get away with installing a PRV in the cold supply to it.
Remember that to comply with water regs you need a double check valve in the cold supply too.
Reply to Mixer tap on a gravity fed hot water system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
