Discuss Mixer tap weaker flow when tap turned to maximum in the Canada area at PlumbersForums.net
I have a kitchen mixer tap with one simple lever controlling temperature and flow. The street water was cut off for a few hours. After that, the hot water flow worked as before, but the cold water flow was very weak. With the tap set to cold, if I open the tap about half way, the flow is the same as it was before the cut off for that half way point, but If I open the tap fully the flow is very weak and much less than the half way flow. The strongest flow is when I have the tap in the middle between hot and cold. Any suggestions, thank you..
Reply to Mixer tap weaker flow when tap turned to maximum in the Canada area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
