Discuss Monobloc ceramic-cartridge tap turns the 'wrong'way in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just replaced my ageing basin and bath taps and wastes with appropriate Bristan equivalents. All but one have conventional valves; , the one exception – a N SNK EF C 1901 Easyfit Kitchen Sink Mixer monobloc – has ceramic cartridges and both H and C turn the ‘wrong’ way (clockwise to turn on). This may be by design, e.g. Bristan repurposing cartridges from lever taps, but has (justifiably…) upset my wife and I am in the doghouse. Can the cartridges be rejigged or even changed, or must I accept this counter-intuitive bit of design?
Swap them around eg hot in cold and cold in hot then adjust the handles to match vis the splines
The cartridges fitted were both Hot cartridges, and these turn on clockwise. Reversing the cartridges on the two sides will make no difference. I had a chat with Bristan who confirmed that ‘clockwise is ON’ cartridges are fitted to these taps by design. (Apart from direction of turn and a coloured band on the base, there is no other difference between between H and C cartridges)
Dissecting a cartridge shows that the cartridges are built for H or C and there is no magic pin or whatever that can be switched around to change the direction of ON/OFF.
Bristan are aware that some customers who also have conventionally-valved monobloc taps (which, like single conventional taps, gate valves and the like are ‘anticlockwise is ON’) may find the difference confusing and they will sell a pack of two C valves for £17.41 (their SKU 2701225300). I have stumped up, fitted them and peace reigns in the household.
I had always assumed that the cartridges were marked blue for cold and red for hot. I learned this week that the colours are just to differentiate clockwise from anti-clockwise operation. There are no differences mechanically in the cartridges, only the direction of operation. This may not be news to old hands but it was to me!
Thank you for this bit of info, fed up with soaking ourselves, its been two years and none of us has got the hang of righty tighty lefty lucy being reversed. It goes against the natural order of the world 😂
Some cartridges you can dismantle and then remake them to operate the opposite way around - I first discovered this by mistake of course!
Have a tinker.
I suffered from this, too and may wife (and I) was furious. I rang up and gave Bristan a hard time and they caved in and sent replacement cartridges for free. It may have helped that I bought the entire tap as a replacement from Amazon and told them I'd send it straight back if they were so stupid as to arbitrarily change the on/off action of taps when almost every other tap in the UK (well in our house at least) worked the opposite way without at least making it very clear. I was only changing the tap because I was always having to strip down the old valves, having already replaced the them twice in just over ten years. Useless idiots!!
Reply to Monobloc ceramic-cartridge tap turns the 'wrong'way in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I know it is not normal practice to use a replacement HOT water ceramic valve/cartridge in COLD water monobloc mixer tap. However, I have been...
3K
Welder
W
B
  • Locked
Hi, I am new to the forum and hope you can help me. We have H&C m0204 lever taps in the kitchen and it has started to drip and I need to replace...
2K
M
  • Locked
Hi Would love some advice please. I cannot for the life of me see how I can get the tap handle off in order to fit a new cartridge. The handle...
6K
  • Locked
I have a monobloc kitchen tap with separate hot and cold water ceramic disc cartridges. The H.W side drips. I tries to unscrew the recessed...
7K
REDSAW
R
T
  • Locked
Hello All It's 03:30 in the morning I have just joined and this is my first post. I have just given up in replacing a ceramic disc cartridge...
21K
Plum Bob 66
