Discuss Monza heatline hot water issue in the Gas Engineers Forum area at PlumbersForums.net
Good evening ,
Heatline monza, pressure gauge rises and reacts as if air hitting the exchanger, boiler cuts out then back on it then opens the prv. This only happens when there is a demand for hot water. Heating seems to run smoothly with minimal increase in pressure. I checked expansion vessel and this was fine. Is it possible dhw plate exchanger partially blocked
Good evening ,
Have you checked the 2filters
Reply to Monza heatline hot water issue in the Gas Engineers Forum area at PlumbersForums.net
