Discuss Morterised valve and tank thermostat (danfoss) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Richard Stewart
I have recently bought a new house and have just found out my hot water button will not fire up my oil fired boiler!! But it works OK when just heating the rads. I have now discovered the tank mounted thermostat was not wired up!!!
It is on a S plan sytem and I tried to connect up with no joy.
The morterised valve up in the hot press goes into a round junction box with 2 other wires which I assume are the boiler and control panel.
The thermostat has only 2 wires brown (2) and blue (1). I tried these in a vary of positions ie- to the morterised valve wires. Which are brown,grey, orange and blue.
The best I could do was get the boiler working but turning the stat into a switch directly controlling the boiler and bypassing the control panel.
Head is wrecked think the guy before me was a nightmare. Please help
Richard.
Before applying any heat to your HW cylinder you need to establish whether it is a vented or unvented system. If you don't know, please post a couple of pictures showing the tank and pipework.
This is a safety issue.
Hi chuck
It's a vented sytem. Water tank in the loft
I would start from the beginning and rewire the lot
You might need to replace the heads if he's cut them back too much
Reply to Morterised valve and tank thermostat (danfoss) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
