Discuss Moving pipe work for sink in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I want to remove my downstairs toilet sink and put a new more compact one on the adjacent wall. However there are two ring drain cocks at the bottom. I want to check that I should replicate the layout rather than just using elbow joints?
Yes, repeat, at the lowest point in the new pipework, as existing.
As you would have found out if they weren't there, it's a lot of messing about with rags, containers and or wet vacs to drain down otherwise.
When you decide the location of the new drain offs, make sure you can get to them when the pipework is finished and any cupbaord boxing in is not in the way.
Hmm. I ideally wanted to box it all in and avoid leaving the pipes like this as it’s ugly. I hopefully will never move the sink again. I’m not averse to wet vacs etc if this is going to be the only time I’ll do it. I’m going to add a couple of valves or flexible tails and a hidden access panel. I wasn’t sure if there was a safety reason for the ring drain cocks?
I wouldn’t bother with the draincocks, and certainly not if you’re boxing it all in.
Tbh they often leak after use anyway so if you have a wet vac there’s no advantage to them.
Reply to Moving pipe work for sink in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet...
B
Hello I’m not going to explain this very well but I will try my best. I’m planning on installing a kitchen sick by myself with no plumbing...
Deleted member 120897
Attached is a ground floor picture of the soil pipe in our home. There was originally a toilet which has now been permanently capped off and you...
