Discuss Narrow Gas fire needed for existing fireplace opening in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Alan_Jeans
Fire needed: I have a fireplace opening that is 380mm wide by 500mm high. I have a gas safe plumber to fit a living flame type fire if I can find one small enough to fit it - Does anyone know of such a fire. It doesn't need to be anything fancy.
<br>Thanks Alex. Much appreciated. I've seen a few fires at that size but when you read the PDF manuals, they state that the minimum clearance required is 405mm - Will the fire in the link you sent definitely fit?
Sorry, talk to your gasman. He should be able to make it happen.
Reply to Narrow Gas fire needed for existing fireplace opening in the Plumbing Jobs | The Job-board area at PlumbersForums.net
