Discuss Need design advice - double combi + tanks in the USA area at PlumbersForums.net
Need some recommendations for a large new build. (400m2)
3 showers, 5 handbasins, 2 baths, 5 WC's, 4 sinks, 2 dishwashers, 2 washing machines.
32mm incoming main at just over 3 bar.
mains gas.
The spec is:
Limitless hot water
full pressure for 3 simultaneous showers (15 lpm each) with zero pressure drop if basins/sink/washing machine etc used.
heating at same time as above
What setup could achieve this best ?
thanks
If it is a new build, I would look at ground or air source heat pumps with either solar thermal or voltaic feeding a suitably sized thermal store.
With respect to hot water - if that is genuinely the specification you need to achieve - it needs to be properly designed. In my experience - to offer a performance guarantee, it will probably need to be driven by a pumped accumulator.
With systems of this scale ask your designer/ installer for references, visit at least one and ask the owner what they think of it.
Hope this helps
That is why the design is important. 3 years ago we retrofitted a 10 bedroomed boutique hotel in Woodstock - with ASHP, thermal solar (to maximise RHI) and 34KW if solar voltaic. Other than an open log fire there are no other heat sources - it is never had a problem even at minus 6 C.
The ASHP - high heat technology available now, would give the system even greater security of supply, at a lower capital cost
Break tank and pump
Accumulator for the toilets
Two Rinnai’s in parallel
heating what’s the load eg kw also ufh etc
thanks, could you explain it a little how it would work ?
break tank and pump would do the baths, showers / high demand items
the 400l accumulator would do the toilets, sinks etc low demand items
the Rinnai’s would be fed from the break tank and pump, also secondary return loop so instant / near instant hot water is accessible
What is the kw rating off the ufh
sounds a great solution, will find out the kwh of the ufh but a normal combi copes with it no problem apparently.
recommend a firm to design and fit the system in Worcestershire ?
Would go air source if you can but over spec it and run a buffer
tbh your best bet is a commercial plumbing and heating
most domestics don’t go that advanced
it won’t be cheap but it will work to your spec
2 x HD 200 Rinnnai units and a 315 litre cylinder will give you near 2000 litres of hot water per hour.
All you need to worry about is the mains pressure to achieve what you want.
Expensive system - but performs and achieves.
Contact Rinnai to help design a system to your requirements.
They are helpful and back up their design with a guarantee
Miss read post - thought you said 8 showers.
1 Rinnai & 250 ltr or 315 ltr tank would be suitable.
In all honesty, you shouldn't be asking advice on a public forum with the specs you have.
If you have doubts about you ability to design a system to the specs required, get some professional help.
I'm not doubting you can do the work, but designing the system may be beyond you.
I only work for a couple of builders now and on the larger projects, I get them to get a design by a Consultant.
Takes a lot of stress off the job as you only have to follow plans provided.
thanks , im not a plumber! Just want to make sure im speccing the right thing. Could you dm me the consultant you use, no problem paying for a spec!
thanks
No.
You want to provide plumbing specifications for a house with 3 showers and you come to an open plumbing forum.
Any domestic plumber should be able to quote on the specifications you require.
If you can't find a domestic plumber that can size and install a system you require - keep looking.
It's not that hard!
Best bet is direct to a manufacturer or a consulting design firm.
You want peace of mind that once installed it meets your requirements.
Out of interest what's the flow out the main litres/minute
thanks, I'll be putting the main in so I could goto 63mm.
thanks for the advise for manufacturer, any particular good ones to speak to ?
Reply to Need design advice - double combi + tanks in the USA area at PlumbersForums.net
