Discuss Need help to find sealing washer for this flush valve. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, can anyone identify this flush valve, there are no manufacturers marks on it, the seal needs replacing, thanks.
Did you find out what the valve was to replace? Please let us know how you got on
Take the washer to merchants , get one with same or larger OD and the same or smaller ID- you can cut them to suit using your original one as a template.
Reply to Need help to find sealing washer for this flush valve. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
