Discuss Need help wiring a new digital thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am removing an old Honeywell thermostat and trying to install a new Drayton Digstat +3. However i cannot understand what wire needs to go where.
The old honeywell wires were as follows:
Brown wire in position 1 which is listed as live on the thermostat diagram
Blue wire in position 2 which is apparantly neutral
Yellow/green wire in posiion which is also apparantly neutral.
On the new thermostat I have 3 connections:
C = I believe the brown live goes here??
ON = I believe the blue neutral goes here??
OFF = I put the yellow / green here ?
Any ideas what this should be? when I try the above the fuse blows on the plug that powers the whole central heating electrics.
Marc
you have a wire missing you should have red,yellow,blue ,yellow and green if your connecting yellow/green to live this will cause a problem as its a earth wire,what system do you have?
think you need a plumber or sparks the neutral has to be re utilised for a switched live by altering in your wiring centre do you know if its a fully pumped system?
red/brown wire to common
yellow wire to call for heat (switched live) to normally on
Stat may not require neutral
Blue is neutral
yes but the op is connecting a green/yellow cable this is a earth or someone has wrongly used it as a control wire
sounds good to me blue wire is for the antisapater sorry cannot spell
yellow green signifies earth
try c brown on blue
nothing connected to off ie - if the digistat has a square within a square symbol it does not require an earth and so if there is no earth connector then tape up the green and yellow wire so that it cannot touch anything
if all works out then the blue wire requires a brown piece of tape at the connection point to signify that it is a switched live and NOT a neutral
not really familiar with digistat but schematic looks simple enough
hope this helps cheers
also the power is separate on this model and comes through the switch fused spur or plug/socket arrangement including a 3 amp fuse and goes to the 2 separate pins
ie 3 pins for thermostat - use 2 and live/ neutral from mains supply
Just tried C = Brown , ON = Blue. the thermostat seems to work but the boiler does not come on at all?
Happy new year everyone by the way!
your better off getting some one in TBH you could damage something or yourself
Reply to Need help wiring a new digital thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
