Discuss Need input with drainage system lay out. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am dealing with a boss that has no mechanical background and a coworker that considers himself to a mechanical God which is leading me to have some concerns about a piping system that they have installed. It consists of some fluid tanks that have overflow drainage leading to a pipe that runs along the floor which finally comes to a vertical rise of about 6 inches, then proceeds to drain to a pit in the floor. I suspect that there will be an issue at the 6 inch vertical lift due to the fact that there is no head pressure in the system. I have a hunch that the overflows will start to back up and not flow freely because of this vertical lift in the pipe which will be detrimental to the proper fluid exchange needed with respect to these tanks. I believe there will be a serious back up or serious flow restriction unless we somehow remove the 6 inch lift or install a booster pump. All input is welcome!!!
Sounds like a good nutty problem. I am interested and have designed stuff like this.
So more detail required. What’s the liquid, are we on the farm ?
What pipe diameters , questions are endless . Do us a piccy or diagram does not have to be professional ...some scale might help. Rob Foster aka centralheatking
Reply to Need input with drainage system lay out. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hello, I'm a homeowner, not a DIYer. I have an almost 1 year old SaniCompact Comfort wall-hung toilet which has worked flawlessly until about a...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
