Currently reading:
Netaheat switches off and back on again
Discuss Netaheat switches off and back on again in the Central Heating Forum area at PlumbersForums.net
Any advice as to what is causing this.
Maybe relevant?
We had a power cut about 5 days ago - I don't think the heating was on at the time but the power cut caused the timer to be reset.
It was the weirdest power cut I have ever experienced... the lights dimmed like some horror film.. but the desktop computer stayed on... eventually the power went off and there was a fault at the local substation - fixed the next day. Having reset the boiler time - - not sure if the next day or after 2 days... the boiler started and then suddenly stopped.. and then tried to start again... started and all worked okay for a few minutes... then off again... it did this for about 5 minutes.
Next 2-3 days all working fine and as per normal.
Today again - it went off and back on again for a few minutes...
It is not 'clicking' and trying to fire - when it clicks/sparks it ignites... and all seems to be okay.
A couple of questions -
1. Could switching it off and 'resetting' it make any difference?
2. Could an airlock in a radiator cause this type of fault?
Anything else?
ps - I know it is old but it generally works fine.
If the boiler was running when you had your power issue. It may have caused issues with a relay on the board. Listen to it when it tries to fire. Buzzing or something similar. The boards are still available if you need one. But you will need a gas safe engineer to fit it.
Reply to Netaheat switches off and back on again in the Central Heating Forum area at PlumbersForums.net
