Discuss New boiler condensate pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Leeroy
Hi all first post so thanks for taking the time to read! As per title I am having a new ideal boiler fitted in my loft soon and have had two different views as to where the condensate pipe should run. One is saying has to run in to the soil stack (which is the other end of the loft so long run) and the second is saying can be run straight out of the gable wall in to the gutter rain water?!
Any thougts on this would be appreciated
thanks Lee
If it's run into the guttering you must have a neutraliser fitted which also must be serviced annually.
Condy pump first option.
Move the boiler closer to the internal soil & vent... Or upsize pipework and ensure it falls all the way! Condense into guttering may freeze & as high level difficult to defrost in future
Reply to New boiler condensate pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Engineer has installed several boilers for me. All the condensate pipes have been connected externally into soil stack or rain water downpipe. In...
Our boiler is in the loft and I encountered a leak in a roof above our side extension store room which has transpired to be from the boiler...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
