- Messages
- 65
Discuss New boiler install - is this acceptable work? in the Gas Engineers Forum area at PlumbersForums.net
It's Pretty awfulIts not pretty
I would have cut a neat hole using one of those pieces (cant recall what its called) at least or put the "L" corner on and then put the pipe in through smaller hole and lined up with the hole they drilled through the worktop.So granted free or low cost ?
normally the lintel extends 150mm max 200mm so they would of been clear
As for the hole I guess they needed to get there hand in there
They took about 6 hours. I had taken down the cupboards for them so they didnt have much to do other than remove old and put new one in. I think one was a trainee.unfortunately they don’t have the time there paid like £200 to install a new boiler
I’m going to take a guess around 4 hours max to install it ?
Yes, I think so. They drained it. I don't know about flushing it. They never attached any hose to wash through.did they clean and flush the heating system?
Yes and on a credit so two potential avenues. This is what the quote said:Did you pay for the install?
If you don’t mind what was the quote ?
it’s for a sealed system to top up the system but yours is open vent I’m guessing
Thanks all for your help.Good luck
Thanks. In the manual, there is a commissioning form that asks if the system been flushed, they ticked yes for it being flushed and then signed it. They then forged my signature on the form to say it had all been explained etc.The best price I can buy that boiler (with flue) for is ÂŁ743 + Vat. The flue centre must be a minimum of 300mm from the inside edge of the door frame - measured horizontally. If it is not - when you receive your Building Control certification call Gas Safe for an inspection.
Read the Valliant users manual, but I think you will find that unless the system has been flushed before the boiler was installed there is no warranty.
If you paid ÂŁ1400 incl Vat - it is a very cheap deal. Just get them back to sort out the builders work and make sure that you have a warranty.
Oh, you've got them by the balls then. Document everything that's wrong including the falsification of a legal document. You have to give them a chance to make good even though you won't want to. Ideally get your solicitor involved to write them a stiff letter to show you mean business. While you're at it fire a letter to Vaillant because I'm sure they'd appreciate their products being installed so shoddily, in the end they have to maintain the product warranty that's been validated by the benchmark (that has been falsified).Thanks. In the manual, there is a commissioning form that asks if the system been flushed, they ticked yes for it being flushed and then signed it. They then forged my signature on the form to say it had all been explained etc.
No point mucking about, send one to the boss...
I was thinking that may be due to covid he signed on my behalf but on reflection the installers should have stated my name on it and just noted not signed due to covid - like the couriers / Royal Mail do.Oh, you've got them by the balls then. Document everything that's wrong including the falsification of a legal document. You have to give them a chance to make good even though you won't want to. Ideally get your solicitor involved to write them a stiff letter to show you mean business. While you're at it fire a letter to Vaillant because I'm sure they'd appreciate their products being installed so shoddily, in the end they have to maintain the product warranty that's been validated by the benchmark (that has been falsified).
Covid may have caused many inconveniences,
Thanks, I have lodged a complaint (including the signature) and will as you and others suggested be getting them to resolve the issue.Why do sound so casual about it?.
It's very shoddy no doubt but is it dangerous or dangerous enough to involve Gas Safe? They don't usually attend where it is a question of very poor workmanship, no harm asking though.That is appalling work I would honestly report this one to gas Safe who will inspect the work it could take a while due to covid ,? and force the installer to put the install right at their cost. Shocking 6 hours for boiler change is no where near enough time to do a quality job here is one I did recently. Regards
Kop
Reply to New boiler install - is this acceptable work? in the Gas Engineers Forum area at PlumbersForums.net
