Discuss New Build - Pipes Not Secured In Walls in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Would someone kindly advise if it’s accceptable for water pipes within walls to a basin be lose and not secured with significant play?
Thanks in advance.
Idealy they would be fixed but the loose pipe police arent going to knock on the door
Whats the story? new bathroom and you are not happy?
Thanks for the advice everyone.
I was just concerned this was not right as some seem secure and others very lose.
There were houses built in the 60s with long runs of copper pipe run under the floors unsupported. It's not a new thing. They are probably mostly still giving good service.
Not ideal, especially now we have quarter turn taps that shut off very quickly, solonoid valves on washing machines and showers, and equilibrium float valves, compared with the old fittings of the day that could only be turned off slowly, but not worth losing sleep over.
Reply to New Build - Pipes Not Secured In Walls in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
