- Messages
- 10
We are renovating our house and after a lot of playing around I have worked out the best floorplan for upstairs. It means the only place I can fit our ensuite is in the middle of the house, the toilet will be 2.7m from the main soil stack in the family bathroom. It is in a straight line and I have checked the direction of the floor joists, but I can't get sufficient fall on the waste pipe to use a standard soil pipe, so we need a macerator.
Due to the small size of the ensuite, we need to use a back to wall or wall hung toilet with the cistern in the stud wall so that there is enough space between the toilet and shower. Ideally I would like the macerator to be in the wall too (I know we need access panels for cleaning/maintenance). The macerator will also need 2 inlets for the shower and washbasin waste, the shower waste will be below floor level though so not sure how we connect it?
This is the only macerator I have found (google search) that will do the job...
Though not sure if this is the same one, it's cheaper and the measurements look slightly different, but still uses a lot of the same photos (confused?) Saniwall Pro Up Macerator Pump | Macerator Pumps
Are there any others out there that might be better? Also, how do we deal with the waste from the shower if it's below the height of the macerator side inlets? Also, is this a job that a good DIYer could do or should we get a professional plumber? We do have an electrician who will be doing all the wiring work. Thanks for any help and advice.
saniflo macerators & macerating toilets
Saniflo Macerators & Macerating toilets. We have the full range of Saniflo macerators & Lifting Stations at the lowest prices online. Next Day Delivery
www.plumbworld.co.uk
