Discuss New Flexi tails leaking on monobloc tsp in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Boaster38
Hi I have a monobloc mixer tap which is 18mths old. a leak appeared underneath in the cupboard which looked to be coming from the flexi tail M8 end I replaced the new tails but when connecting up (hand tight)the leak is worse, is this a tail issue or could it be a cartridge perhaps, I have used ppte tape which improved it but still leaks
Not cartridge if it’s leaking from there.
Were the o-rings in place and in good condition on your tails?
Better tails have two o-rings and these seem to more reliable.
However even with no o-ring you should be able to get it leak free using ptfe.
Pictures would be helpful.
The first instance could be condensation perhaps.
PTFE maybe used in some situations but many times applied incorrectly. May you can get a better sealing compound?
Reply to New Flexi tails leaking on monobloc tsp in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
