Discuss new installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi guys
well a update on the new sys, its all up and running took longer than 2 days went into 3, what more can i say the sys has been reg with gs and worcester, no leaks , only issue i had which was put right was 2 rads were 3inches off the ground, got him to lift them upto 6inches, all benchmark paperwork completed and jobs a goodin and heats the house up in about 30-40 mins
Good result, glad you are happy
We love a good boiler picture here:bucktooth:
nope its horizontal, pics req of that ?
also its connected to a mixershower (mira discovery) and its out this world, dreading my waterbill, love it
It does look like a DIY job but if it works and you are happy then thats the main thing
It looks very diy. Those speedfit fittings are totally unnecessary and look horrible. Still if you're happy then we're happy for you.
Love to see the flue and condense tho please!
Hmmm speedfit does not look good, also plugged not on fuse spur, unstraight pipework
Too many elbows. Rotating heating return 90 degree and similar consideration to cold water feed would both square and simplify pipework. More bends and X overs could be pulled and much of the pipework could have been made up on bench, if confidence to solder in place lacking. Copper pushfits to replace plastic on 22mm heating runs would have been better at minimal additional cost. Better still, having cut and formed pipework, pay heating engineer to solder joints whilst he was doing gas supply.
It doesn't look bad (expected it to be push fit fittings) but would like to see where the high temp blow off goes (copper pipe by the plastic overflow pipe) and flue
the reason i got tld for the nonfuse socket is was the was pulled up by a gas safe inspection and told him its not to have a switch on ???? i`m only going off what he told me
we have a saying if its not broken dont fix it and its running like a dream, i did watch it get so many drains the water was clear and watched him sticking a bottle of f1 in, full benchmark paperwork all filled in, called gs up and confirmed its been registered
i let you guys discuss oh and here is the flue
Reply to new installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys Im doing a new build near Brecon, Powys. Its going to have oil boiler, heat store (big one) and radiators. No under floor heating. The...
Hi, new member here, so hello! I recently bought a house that needs heaps of work, so have no money and lots to learn along the way. Ive had a...
2K
Hello , ive recently gone out on my own, i have been working in the industry 15years now /g3 qualified and i would just like to get some advice...
3K
I'm looking for clarification if possible. I was asked to service a vokera combi, turned up and clocked that it seemed brand new, socket was...
Hello, Just wondering what is the best (cheapest) way to go about getting a new gas supply installed. The property is a first floor flat which...
2K
