Currently reading:
New Kitchen Waste Run Correct Pipe Size
Discuss New Kitchen Waste Run Correct Pipe Size in the USA Plumbers Advice area at PlumbersForums.net
Hello PFM's,
I have the pleasure of doing my first waste run for a new kitchen installed in a flat and was hoping for some advice.
I need a 6-metre run to the stack where I am going to mark my 1:40/1:110 and split the difference at a 1:80 gradient. It will be discharging the kitchen sink, dishwasher and washing machine.
What pipe size would you recommend, don't have a copy of building regs. Would a 40mm pipe suffice or should I go up on that dia.?
Thanks in advance.
Baz.
Are they going to be discharging all at the same time
Also 15mm a meter normally is around the mark
11/2 should be fine if you want you could up the waste to 2" if you want that would handle anything
Reply to New Kitchen Waste Run Correct Pipe Size in the USA Plumbers Advice area at PlumbersForums.net
