Discuss New member saying hi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, new to this forum and just saying hi.
Qualified as a Gas safe engineer in May and setup as a Heating and Plumbing Engineer straight after.
Joined to help others who have just started and also to tap into the wealth of knowledge the grand masters on here have.
Thanks in advance for any help I receive as and when I cry for some!:rolleyes:
This forum may have saved my life. We has a water leak and found the plumbing was black non-standard plastic piping around 17-18mm. Advice on using Philmac Universal coupling may be the only solution.
Great advice great forum and thanks for letting be join.
Anyone know a good plumber near Croydon?
Hi Sukhi,
Good luck to you, it was 10years before I went out on my own and I still miss the support of a team.
I'd reccomend you get in with a veteran locally even if it's helping out occasionally a low rate, it's always good to have someone around when you need help!
hello and welcome
Reply to New member saying hi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
