Discuss New monument pipe benders in the Plumbing Tools area at PlumbersForums.net
Jim Goodenough
Has anyone experience of the new Monument benders?
Any feedback?
Got a link? Didn't know they had a new pipe bender.
YOu mean the Monument Masters that just bend 15mm? Don't know tbh. However I'd guess that the yellow monument benders are China made nothing like the old ones so rippletastic.
You want BentitNow benders that used original Hilmor tooling.
Loks like Monument do 1 for 22mm and another for 15mm
Ive got both sizes. The 15mm works really well, the 22 is good but the arms even with extensions don't give great leverage so can be tricky to pull. as a pair they take up more space on the van than my old hilmor bender as you really need both sizes. Although it has a built in guide, it's only made of plastic so I'm not confident it will last as long as the traditional metal ones. I don't know if monument sell it as a spare part but if they don't, I cant imagine I would ever invest in a new bender if it broke.
I have the 15mm set. They are pretty short so storing is not an issue. I strap them on my bahco soldering kit bag. They are so easy to use as it retains a decent length of 15mm in the first section of the bender whilst you hook the second part. No messing about trying to hook the former in. The nylon former is a serviceable part but no idea how long they last. It creates a nice bend and so quickly. Not had any bends ripple yet and i just yank on those handles and pull that 90. My standard benders, both sets often ripple and need bends pulling slowly. Even with a new set of hilmors with new formers i still often got ripples. For just pulling short 90s or offsets, not fighting with the weight and size of the arms of a traditional bender, this thing is way better. You can also get extension handles that are 1/2inch thread which somebody pointed out the other day can be used as handles to carry around the big rads. You don't need the handles for 15mm, its pretty easy. I have found myself pulling bends more often on small jobs rather than using fittings and soldering as its now more convenient than previous, when i couldn't be bothered to go and get my benders from the van. I still have to have traditional benders for 22 but i should just get the 22 set also really. Id suggest for you to pull the trigger and get a set as they are brilliant.
For me the best solution for benders is old records on eBay. I brought a used once red record 15/22 for ÂŁ35 last year in its box. I also have 2 record solos which are 15mm only(one brand new in box still) paid about ÂŁ20 each for those. No ripples, no slack, 15mm solos do tight 180 bends. Can't beat tools from 30 years ago.
Reply to New monument pipe benders in the Plumbing Tools area at PlumbersForums.net
