Discuss New pump required on system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Neil T
Subscribed
Hi all,
I was round at a customers the other day and he mentioned that his top floor rads weren't heating up (they are in converted loft). As it was on a tank and cylinder system I checked where the tank was sited and found that the top of the 2 rads are actually 30cm above base of tank. I bled the rads but obviously as not enough pressure i got no water out of them. There is a grundfos ups 15-60 pump on the system but obviously not strong enough for the top 2 rads.
I don't do much heating work, mainly bathrooms and maintenance work, so any recommendations on a better pump to suit this situation would be appreciated.
Seal heating system and fit a correctly sized pump
As shaun has said pressurise the system you will probably find pump will be ok then . cheers kop
The grundfos pump is probably big enough for the job but is a circulator, not a pump as such.
The f&e tank must be above the highest radiator in order to heat the rads.
If the tank cannot be raised then the system could be pressurised to give enough head to heat the radiators but this would be conditional on whether or not the boiler is suitable for this.
No room to move f&e as loft has been converted and that's where rads are .. water cistern and f&e are in cupboard at side of one of converted rooms.
What does pressurising system entail?
Thanks for the info guys
Need to call back to customer to check out what the boiler is, whether it's suitable and to see if there's enough room near it for exp vessel and prv
Definitely best place for expansion vessel and kit is usually close to boiler.
If that proves impossible you could fit the expansion vessel remotely, also the filling loop anywhere handy for to use.
But the pressure relief valve should be fitted close to boiler IMO.
If the current set up has the water fill level at same height as highest rads, then they will work, but obviously not ideal. Lower rads would have been more sensible.
If you tried fully bleeding the upper rads while the pump was running, it sometimes works and rads will fully fill if pump was on flow pipe.
Thanks again
I put the heating on whilst I went to do the job i originally was called to do then bled the rads after about 30 mins. Both just gave up the ghost after around 1 min.
As I said, i will check out the boiler and that, and size up the work involved and if it's out of my comfort zone I think I'll pass the job over
Reply to New pump required on system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
Hi we have a Alpha 2 15-60-130 central heating pump fitted. We need a bit more heat from 12 rads. I’m confused about the settings as the Auto...
Hi All...thx for the help in advance. I have recently installed a wood burner with back boiler heating system. Set up with gravity rad and header...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t...
