Discuss New Radiator Size Issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have bought new radiators to replace my current ones (around 25 years old). Old radiators were all fitted with TRV's.
I have put the new 15mm compression inserts into the radiator that came with the new valves/TRV's but this then makes the valves too wide to fit onto the existing pipes (by around 20mm). I think the old radiators had the inserts that have to be put in with a radiator valve key.
Do the threaded parts of the radiator that the inserts screw into come up different widths on different brands?
any chance of a pic of the new valves?
These are the valves/TRV (Drayton RT212).
https://www.NoLinkingToThis/p/chrome-angled-radiator-valve-drain-off-15mm-x/70408
Time to re jig and put a set into the pipes
Ok thanks for all the replies. Looks like getting small radiators with the tail extensions will be the best option. Pipes are in a concrete floor as well which is more difficult as there is no movement on them.
Cheers for the help.
If you own a pipe cutter the one on the right is less likely to leak than the one on the left.
Getting the thread to seal in the radiator can be a bit of a pig if you use PTFE. £20 for a bottle of Loctite 577 even if it’s only for this one job may well save you a lot of hassle in the long term.
Reply to New Radiator Size Issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I want to swap a K1 radiator with a P+, the same size on a combi system. Can i turn off both valves, remove the existing radiator, put the new one...
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
Hullo everyone its a while since I posted on here basically because i have had no plumbing issues however I have one now. My son recently moved...
I have recently bought my own house and decided to redo the kitchen. There was a radiator in the room already but I wanted to move it. I extended...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
