Discuss New strainer needed. What is the proper name for this? in the USA area at PlumbersForums.net
Removed this from a valve in my heat pump it needs replacing as the top ring now loose.
Does anyone know what its called and where to get one.
you could clean it up and solder it onto the filter mesh
As above the strainer manufacturer should have spares , but it could be repaired as Shaun says its a basket mesh filter you could try online.? I found this company with a simple search on Google
Reply to New strainer needed. What is the proper name for this? in the USA area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
