J
jim.allwood
Hi all. This is my first post, so be gentle if I don't follow code.
My uncle has just had a new central heating system fitted in his new barn conversions. He's had a mistral 35kw oil combi fitted. Problem is that the rads take for ever to heat up. And the boiler keeps going off as it reaches its maximum temp. I asked what the plumber had done with the pipework and it looks like he reduced the 22mm feed down to 15mm, teed it and then taken 2 x 10mm pipes off the feed to supply all 13 rads.
To me that's an obvious bottleneck and the boiler just can push the water around the system fast enough.
Am I correct to assume this?
