Discuss New thermostatic shower cylinder fitted - now water is not hot enough in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a Bristan mixer shower. It started leaking from the temperature control. A local plumber replaced the thermostatic cylinder. It now doesn't leak - but the water is now 15-20 per cent colder than it was before when the temperature is at max hot. Why? What's amiss here?
Reply to New thermostatic shower cylinder fitted - now water is not hot enough in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
I need to change my shower mixer and I have a unvented hot water cylinder. Is it sufficient to turn off the mains? Do I need to drain the...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
Hello! Im Martyn Im new here and have joined for some advice on a couple of things. Ive got an issue with a Mira mixer shower that has...
