Discuss no hot water of heating in the USA area at PlumbersForums.net
I have no hot water or heating, my boiler has no error symbols, my cylinder has gone cold, pump seems to be working well it’s making the same usual noise/vibrations, pipe under th boiler are hot but none near the cylinder is! Can anyone help
Do you have water in the system. Is it open vented or sealed.
Hi I’m not sure! It has an 3 tanks in the loft A cylinder in a cupboard and a boiler!, I’m by no means a plumber/heating engineer, yeah there’s water in the system! After resetting the boiler, pumps
[automerge]1579472670[/automerge]
Hi I’m not sure! It has an 3 tanks in the loft A cylinder in a cupboard and a boiler!, I’m by no means a plumber/heating engineer, yeah there’s water in the system! After resetting the boiler, pumps and motorised diverter valve it’s started getting hot water into the pipes where the cylinder in but still no hot water/heating yet!
[automerge]1579472709[/automerge]
Link out the heating controls to rule them in or out. Check any port valves are operatinal
Wouldn’t have a clue how to do that!
[automerge]1579472741[/automerge]
Do you mean bypass the thermostats
If your central heating is functioning perfectly but there is no hot water coming from your shower or taps, it is likely an issue with the diverter valve. If you are experiencing this problem then the diverter valve may be faulty, or it may be stuck in the central heating position.
Reply to no hot water of heating in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
PSxxxxxx
