- Messages
- 193
Hi all. I have an old floor standing o/f boiler which isn't giving hot water. I'm wanting to go back to basics on this one as I've tried the 'normal things'!
pumped heating, Gravity dhw. There is a room stat for heating but no stat for hw both are controlled by very old programmer. When I put dhw water only on and switch it to constant I get a hot flow pipe to cylinder but nothing coming out.
i don't think its air in the coil as there is a lovely upward run but to the vent pipe. I've cracked the nut on the flow at cylinder and just got water. Tried bleeding towel rad on circuit, nuts water. Tried pulling through with a hose on the return at the boiler and had my wet vac on the vent sucking any air back.
suggestions would be awesome as I'm beginning to scratch my head and don't really want to take the cylinder out to check for blockages as I believe God put it in in his younger days!!!!
