Discuss No Hot Water Or Heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
help
Hi
I have no hot water or heating, I have system boiler and cylinder is on the landing
the boiler lights and that is it can any body help, neighbour thinks it the valve in the airing cupboard, does that sound right to anybody and how do I test it.
don't what to replace it if not broke.
Can't afford to , is there a check that can be done to show if at fault.
You most likely wont be able to replace the pump yourself anyway, and may cause loads of problems if you do - fiddling aroung with old heating systems is complicated even for those of us in the know . . .
You could also check yourself - but you have to be aware that if you call in someone and tell them its the pump (and it isnt) you will end up paying more for the job)
Dont second guess, get a proffessional in (ask for a free quote though!)
Have hot water , Have moved the arm on valve to manual and now have heating
but radiators only hot upstairs, cold down stairs, would this suggest the pump
It probably would - the MOV might need a look if you have to move it yourself to open the circuit . . .
Reply to No Hot Water Or Heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
