Discuss No inhibitor, is it too late? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sid Viscous
Subscribed
Evening hive-mind,
Yesterday I serviced a 5yr old Ideal combi. When I took the top off the magnaclean, (which was chocka,) I was alarmed to see the system water was the colour & consistency of cream of tomato soup! I didn't need a test kit to realise that there's no inhibitor in the system. Obviously the system is corroding from the inside out. It's piped up entirely in plastic with normal steel panel rads.
My question is would a p-flush & retreatment be the way forward or is the damage already done & he'll have to have all the rads changed?
Yes best way
Even a hot flush would be better than nothing
It's that grey stuff. Don't use it myself so not sure on spec...
Theres a few different types that are grey...you would have to read the side of it or look at a cross section to confirm. Seen a couple of installs in non barrier that have sludged up massivly supposedly down to the non barrier ingressing air
Never to late bud get it hot flushed , cold flushed you can then power flush it to removed any stubborn debris will take you all day to do a proper job . Cheers kop
I seem to recall, somewhere in the dim & distant past, reading that once corrosion has set in that it can't be halted. Could be my memory having me on or a spot of paranoia! I suppose there are 40yr old primatic systems still running out there that have never had inhibitor in them....
Reply to No inhibitor, is it too late? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
