Discuss Noisy combi boiler strange repair option in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaz
Our worcester greenstar he boiler sounds like a world war 2 lancaster bomber trying to take off !
This happens when it first switches on in the morning - whenever the hot tap
is turned on - or it pumps water when the thermostat clicks it on.
An engineer has suggested we should add an extra "tank" of some sort of repair
Can anyone tell me what this is - is it a manufacturers recommended "fix" or what? Is it safe and is it normal to do this?
also does anyone know where I can download a manual for this - I cant find one on the worcester site ... have I just missed it?
The boiler is 14 years old.
When was it last serviced ?
Agreed I’ve just had the same issue with a different model has engineer in fact just picked up on wear and tear issues and is repairing it accordingly before noise is addressed
it was serviced 10-07-17 and every year previously.
Does the suggested repair sound correct to you?
PS - I've found a manual now.
NO sounds like he's suggesting adding another expansion vessel
TBH I would get a second opinion from a gas safe engy
hi shaun
thanks for the quick response.
That sounds very definite.
Can you say why so I can tell him why I don't want it done that way?
Do you have to keep topping the pressure in the system up ?
it doesn't need topping up that more than about every 3-4 months or so I think. the other issues it has are randomly switching off and not heating radiators regardless of thermostat (I power off and on and it runs ok again) This does cause serious problems but not technical ones. That is worse in cold weather presumably because its on longer.
And the water out of the hot tap is very white and milky (it hasn't done that like that since it was new)
I would say you have other issues that an expansion vessel won't solve
Yes I think you're right.
Can you explain why adding another expansion vessel is not a good idea though?
Time to start thinking about a replacement boiler ! at this age just be careful what you spend on it,
It's not a bad idea just wasting money unless you've got a really big system then again you wouldn't have a combi boiler
just for info for everyone....
It seems some sort of rubber diaphram had split in half and got
sucked into a fan. The final repair took about ten minutes.
Thanks for all the suggestions though.
Reply to Noisy combi boiler strange repair option in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
